주요 콘텐츠로 건너뛰기
Gateway Solo 1450 Battery Replacement
  1. Gateway Solo 1450 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
    • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
  2. Gateway Solo 1450 Battery Replacement: 2 단계, 이미지 2개 중 1개 Gateway Solo 1450 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
  3. Gateway Solo 1450 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Timothy Post
회원 가입일: 03/20/18
112 평판
안내서 1개를 작성함
UMass Dartmouth, Team S5-G4, Peak Spring 2018 UMass Dartmouth, Team S5-G4, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G4
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 341
