주요 콘텐츠로 건너뛰기
Gateway Solo 1450 Optical Drive Replacement
필요한 것
  1. Gateway Solo 1450 Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
    • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
  2. Gateway Solo 1450 Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 Gateway Solo 1450 Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
  3. Gateway Solo 1450 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
  4. Gateway Solo 1450 Optical Drive Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Gateway Solo 1450 Optical Drive Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Orient the laptop open to see the keyboard. Have the screen tilted all of the way back for easier access as shown.
  5. Gateway Solo 1450 Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Above the keyboard, locate the plastic part containing the power button along with various other command buttons. This needs to come off before you can access the keyboard.
    • Use the spudger to assist in this step. Using the spudger, wedge it underneath the component.
    • Once spudger is inserted and pulled far enough, grasp it and firmly, but carefully, pull it out from the left side first
  6. Gateway Solo 1450 Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 Gateway Solo 1450 Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 Gateway Solo 1450 Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Once unattached from left side, proceed to right side of component and remove it from clips it is attached to.
    • Once removed from clamps, the part is now removed to provide access to the keyboard.
  7. Gateway Solo 1450 Optical Drive Replacement: 7 단계, 이미지 2개 중 1개 Gateway Solo 1450 Optical Drive Replacement: 7 단계, 이미지 2개 중 2개
    • The two J0 screws have now become visible. Using the Phillips J0 screwdriver, remove screws. The screws are 5mm long J0 Philips screws.
  8. Gateway Solo 1450 Optical Drive Replacement: 8 단계, 이미지 3개 중 1개 Gateway Solo 1450 Optical Drive Replacement: 8 단계, 이미지 3개 중 2개 Gateway Solo 1450 Optical Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Once screws are removed, firmly grasp the top edge of the keyboard and wiggle it slightly while firmly tugging on it. This will release the clips holding it.
    • Once clips become unattached, the keyboard is now out.
  9. Gateway Solo 1450 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 1개 Gateway Solo 1450 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 2개 Gateway Solo 1450 Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 3개
    • Locate the optical drive.
    • Locate the points where the optical drive is secured to the laptop's interior with screws.
    • Unscrew the screws holding the optical drive in place.
  10. Gateway Solo 1450 Optical Drive Replacement: 10 단계, 이미지 2개 중 1개 Gateway Solo 1450 Optical Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the optical drive from the laptop's interior.
결론
작성자
1다른 기여자 명과 함께
Zachary Perry
회원 가입일: 03/20/18
484 평판
안내서 4개를 작성함
UMass Dartmouth, Team S5-G4, Peak Spring 2018 UMass Dartmouth, Team S5-G4, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 393
