소개
This repair is needed in situations where your keyboard stops working. If you have checked that all the keys are properly seated and that there is nothing blocking key movement, replacing the keyboard should correct the issue.
필요한 것
Slide the locking switch towards the open lock picture.
Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
Once the laptop is disengaged, completely remove the battery from the laptop.
Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
Remove the 4mm Phillips #0 screw that secures the keyboard.
Reposition the laptop so that it is upright with the display open.
Carefully pry up on the right and left sides of the speaker cover panel.
Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
Pull on the cord connecting the keyboard to the computer until it slides out.
Thank you! This is a first time repair for me, and it worked!
As for step 8, my Gateway W350I has a cable retainer. The first time I tried the repair, the keyboard wouldn't work. Sure enough, the cable got loose after I tried putting it in. On the second attempt (after some research on my phone), I carefully nudged the tabs on the retainer 2 mm away from the connector, put the cable in, and nudged the tabs back into the connector. After the cable was locked, the keyboard worked perfectly.
다른 2명이 해당 안내서를 완성하였습니다.
