주요 콘텐츠로 건너뛰기
Gateway W350I RAM Replacement
필요한 것
  1. Gateway W350I RAM Replacement, Battery Access: 1 단계, 이미지 1/1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I RAM Replacement, Unlocking the Battery: 2 단계, 이미지 1/3 Gateway W350I RAM Replacement, Unlocking the Battery: 2 단계, 이미지 2/3 Gateway W350I RAM Replacement, Unlocking the Battery: 2 단계, 이미지 3/3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I RAM Replacement, Remove Bottom Cover: 3 단계, 이미지 1/3 Gateway W350I RAM Replacement, Remove Bottom Cover: 3 단계, 이미지 2/3 Gateway W350I RAM Replacement, Remove Bottom Cover: 3 단계, 이미지 3/3
    • Turn the laptop over to remove the plastic cover.
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I RAM Replacement, Removing RAM Chips: 4 단계, 이미지 1/3 Gateway W350I RAM Replacement, Removing RAM Chips: 4 단계, 이미지 2/3 Gateway W350I RAM Replacement, Removing RAM Chips: 4 단계, 이미지 3/3
    • Gently pull the first RAM chip to slide it free from the mounting on the board.
    • Gently pull the second RAM chip, located under the first, to slide it free from the mounting on the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Austin
회원 가입일: 09/22/14
249 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 회원
USFT-BROWN-F14S4G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,725
