주요 콘텐츠로 건너뛰기
Geardup RC Ford Mustang GT Motor Replacement Guide
필요한 것
  1. Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 1 단계, 이미지 1/3 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 1 단계, 이미지 2/3 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 1 단계, 이미지 3/3
    • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
    • Gently lift the battery cover from the car to expose the batteries.
  2. Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 2 단계, 이미지 1/2 Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 2 단계, 이미지 2/2
    • Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
  3. Geardup RC Ford Mustang GT Motor Replacement Guide, Shell: 3 단계, 이미지 1/1
    • Flip the car over again to its upright position and vertically lift the shell from the car.
    • During re-assembly, make sure the shell is correctly aligned. If it is not aligned correctly, it may rub on the wheels, possibly preventing them from turning.
  4. Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 4 단계, 이미지 1/2 Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 4 단계, 이미지 2/2
    • Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
    • Slide the wheel off of the axle.
    • Repeat the previous steps for the other rear wheel.
  5. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 5 단계, 이미지 1/2 Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 5 단계, 이미지 2/2
    • Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
    • Vertically lift the motor/circuit board enclosure from the car chassis.
  6. Geardup RC Ford Mustang GT Motor Replacement Guide: 6 단계, 이미지 1/2 Geardup RC Ford Mustang GT Motor Replacement Guide: 6 단계, 이미지 2/2
    • Using a small plastic opening tool, gently pry the clips to release the tabs on the circuit board casing. The clips can be located above where the rear wheels used to be.
    • Lift the clips just enough to release them from the tabs. If they are pried too far, they may snap off.
    • There is a clear gear grease inside the enclosure.
  7. Geardup RC Ford Mustang GT Motor Replacement Guide: 7 단계, 이미지 1/2 Geardup RC Ford Mustang GT Motor Replacement Guide: 7 단계, 이미지 2/2
    • Lift the circuit board casing from the enclosure to reveal the motors, gears, and circuit board.
    • During re-assembly, make sure the wires are not pinched between plastic dividers in the enclosure as this may damage them.
  8. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor: 8 단계, 이미지 1/1
    • Using the copper solder wick, remove the solder from the two wires at the points where they connect to the motor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Seno
회원 가입일: 02/01/15
191 평판
안내서 1개 작성함
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G38
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 369
