주요 콘텐츠로 건너뛰기
Geardup RC Ford Mustang GT Remote Circuit Board Replacement
필요한 것
  1. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 1 단계, 이미지 1/3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 1 단계, 이미지 2/3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 1 단계, 이미지 3/3
    • Remove the 5mm Phillips #0 screw from the remote control.
    • Using the tab, lift the battery cover from the remote control to expose the battery.
  2. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 2 단계, 이미지 1/2 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 2 단계, 이미지 2/2
    • Unscrew the six 5mm Phillips #0 screws on the back of the remote
    • Separate the back of the remote from the front panel.
    • During re-assembly, make sure the plastic button covers on the front panel align with the buttons on the back panel. If they do not, the buttons may be forced into an always "pressed" state.
  3. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove the two left and right buttons from their insets in the controller.
  4. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 4 단계, 이미지 1/1
    • Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
  5. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 5 단계, 이미지 1/1
    • Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Remove the circuit board from the casing.
  6. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 6 단계, 이미지 1/1
    • Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Using the copper solder wick, remove the solder connecting the nine wires to the circuit board.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jake Stone
회원 가입일: 02/01/15
611 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G38
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 18
전체 시간: 6,036
