주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GeeksPhone Keon Antenna Replacement
필요한 것
  1. GeeksPhone Keon  Antenna Replacement, Battery: 1 단계, 이미지 2개 중 1개 GeeksPhone Keon  Antenna Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon  Antenna Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the cover away from the phone.
  3. GeeksPhone Keon  Antenna Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon  Antenna Replacement, Back Plate: 4 단계, 이미지 2개 중 1개 GeeksPhone Keon  Antenna Replacement, Back Plate: 4 단계, 이미지 2개 중 2개
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon  Antenna Replacement: 5 단계, 이미지 2개 중 1개 GeeksPhone Keon  Antenna Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon  Antenna Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon  Antenna Replacement: 7 단계, 이미지 3개 중 1개 GeeksPhone Keon  Antenna Replacement: 7 단계, 이미지 3개 중 2개 GeeksPhone Keon  Antenna Replacement: 7 단계, 이미지 3개 중 3개
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon  Antenna Replacement: 8 단계, 이미지 2개 중 1개 GeeksPhone Keon  Antenna Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the backplate away from the device.
  9. GeeksPhone Keon  Antenna Replacement, Antenna: 9 단계, 이미지 1개 중 1개
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
  10. GeeksPhone Keon  Antenna Replacement: 10 단계, 이미지 3개 중 1개 GeeksPhone Keon  Antenna Replacement: 10 단계, 이미지 3개 중 2개 GeeksPhone Keon  Antenna Replacement: 10 단계, 이미지 3개 중 3개
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
결론
작성자
3다른 기여자 명과 함께
Michael Moran
회원 가입일: 08/26/15
116 평판
안내서 1개를 작성함
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 32
전체 시간: 342
