주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GeeksPhone Keon Battery Replacement
필요한 것
  1. GeeksPhone Keon Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 GeeksPhone Keon Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    댓글 쓰기
  2. GeeksPhone Keon Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the cover away from the phone.
    댓글 쓰기
  3. GeeksPhone Keon Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Yanni Worthington
회원 가입일: 08/26/15
343 평판
안내서 3개를 작성함
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G5
4 회원들
안내서 12개를 작성함
4가이드 댓글
Newer Keon model has user replaceable battery GP-BA002
gintasdx - 답글 공유
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
gintasdx - 답글 공유
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - 답글 공유
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 28
전체 시간: 1,006
