주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GeeksPhone Keon Motherboard Replacement
필요한 것
  1. GeeksPhone Keon Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 GeeksPhone Keon Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    댓글 쓰기
  2. GeeksPhone Keon Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the cover away from the phone.
    댓글 쓰기
  3. GeeksPhone Keon Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    댓글 쓰기
  4. GeeksPhone Keon Motherboard Replacement, Back Plate: 4 단계, 이미지 2개 중 1개 GeeksPhone Keon Motherboard Replacement, Back Plate: 4 단계, 이미지 2개 중 2개
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    댓글 쓰기
  5. GeeksPhone Keon Motherboard Replacement: 5 단계, 이미지 2개 중 1개 GeeksPhone Keon Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the small orange plate by pulling it down.
    댓글 쓰기
  6. GeeksPhone Keon Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    댓글 쓰기
  7. GeeksPhone Keon Motherboard Replacement: 7 단계, 이미지 3개 중 1개 GeeksPhone Keon Motherboard Replacement: 7 단계, 이미지 3개 중 2개 GeeksPhone Keon Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    댓글 쓰기
  8. GeeksPhone Keon Motherboard Replacement: 8 단계, 이미지 2개 중 1개 GeeksPhone Keon Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the backplate away from the device.
    댓글 쓰기
  9. GeeksPhone Keon Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 GeeksPhone Keon Motherboard Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
    댓글 쓰기
  10. GeeksPhone Keon Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    댓글 쓰기
  11. GeeksPhone Keon Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Yanni Worthington
회원 가입일: 08/26/15
343 평판
안내서 3개를 작성함
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G5
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 31
전체 시간: 416
