주요 콘텐츠로 건너뛰기
General Disassembly LG VX8560
필요한 것
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: 1 단계, 이미지 1/1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: 2 단계, 이미지 1/1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: 3 단계, 이미지 1/1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: 4 단계, 이미지 1/1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: 5 단계, 이미지 1/2 General Disassembly LG VX8560: 5 단계, 이미지 2/2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: 6 단계, 이미지 1/1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jack Foley
회원 가입일: 04/25/13
37 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G62
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 421
