주요 콘텐츠로 건너뛰기
General Electric Bagel Switch 4-Slice Power Supply Replacement
필요한 것
  1. General Electric Bagel Switch 4-Slice Power Supply Replacement, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: 1 단계, 이미지 1/1
    • Unplug the toaster from the electrical outlet.
  2. General Electric Bagel Switch 4-Slice Power Supply Replacement: 2 단계, 이미지 1/2 General Electric Bagel Switch 4-Slice Power Supply Replacement: 2 단계, 이미지 2/2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  3. General Electric Bagel Switch 4-Slice Power Supply Replacement: 3 단계, 이미지 1/1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
  4. General Electric Bagel Switch 4-Slice Power Supply Replacement, Power Supply: 4 단계, 이미지 1/1
    • Flip the toaster over so that the bottom plate is facing up.
  5. General Electric Bagel Switch 4-Slice Power Supply Replacement: 5 단계, 이미지 1/2 General Electric Bagel Switch 4-Slice Power Supply Replacement: 5 단계, 이미지 2/2
    • Remove the four screws from the bottom of the toaster.
    • Carefully separate the bottom plate from the metal components inside the toaster.
  6. General Electric Bagel Switch 4-Slice Power Supply Replacement: 7 단계, 이미지 1/1
    • Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
  7. General Electric Bagel Switch 4-Slice Power Supply Replacement: 8 단계, 이미지 1/1
    • Pull the power supply cord through the bottom plate of the toaster.
    • Insert the end of the new power supply cable through the hole in the bottom plate.
  8. General Electric Bagel Switch 4-Slice Power Supply Replacement: 10 단계, 이미지 1/1
    • Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
    • Splice the stripped ends of wire together using a wire cap.
결론
Ron Gajdos
회원 가입일: 10/16/13
307 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 UMass Dartmouth, Team 4-4, Vijaybhaskar Fall 2013 회원
UMASSD-VIJAYBHASKAR-F13S4G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 484
