주요 콘텐츠로 건너뛰기
General Electric Create Jason Wu LCD Screen Replacement
필요한 것
  1. General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 1개 General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 2개 General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 3개
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
  2. General Electric Create Jason Wu LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 General Electric Create Jason Wu LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
  3. General Electric Create Jason Wu LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 General Electric Create Jason Wu LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 General Electric Create Jason Wu LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
  4. General Electric Create Jason Wu LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 General Electric Create Jason Wu LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 General Electric Create Jason Wu LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
  5. General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2개 중 1개 General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: 5 단계, 이미지 2개 중 2개
    • With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
    • The LCD screen is secured to the frame with a thin layer of adhesive, not much force is required to removed the screen from the back casing.
    • Before replacing the back casing with the new LCD screen, please be sure it is secured into the casing with new adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kailee Poe
회원 가입일: 01/18/17
274 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 302
