주요 콘텐츠로 건너뛰기
General Electric Create Jason Wu Power Supply Button Replacement
필요한 것
  1. General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 1개 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 2개 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 1 단계, 이미지 3개 중 3개
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
  2. General Electric Create Jason Wu Power Supply Button Replacement: 2 단계, 이미지 2개 중 1개 General Electric Create Jason Wu Power Supply Button Replacement: 2 단계, 이미지 2개 중 2개
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
  3. General Electric Create Jason Wu Power Supply Button Replacement: 3 단계, 이미지 3개 중 1개 General Electric Create Jason Wu Power Supply Button Replacement: 3 단계, 이미지 3개 중 2개 General Electric Create Jason Wu Power Supply Button Replacement: 3 단계, 이미지 3개 중 3개
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
  4. General Electric Create Jason Wu Power Supply Button Replacement: 4 단계, 이미지 3개 중 1개 General Electric Create Jason Wu Power Supply Button Replacement: 4 단계, 이미지 3개 중 2개 General Electric Create Jason Wu Power Supply Button Replacement: 4 단계, 이미지 3개 중 3개
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
  5. General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 5 단계, 이미지 3개 중 1개 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 5 단계, 이미지 3개 중 2개 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Locate the metal frame removed from around the camera in step 3.
    • Lay the frame button side down or flat and gently pry the button out of place with the 3.0 flathead bit or a pair of tweezers.
    • This is very brittle plastic so use extreme caution and minimal force.
    • The button is secured to the frame by two small black rods pushed into the white colored portion of the button (see picture).
  6. General Electric Create Jason Wu Power Supply Button Replacement: 6 단계, 이미지 1개 중 1개
    • The button will pry off easily and shouldn't take much force
결론
작성자
3다른 기여자 명과 함께
Kylan Hennessy
회원 가입일: 01/23/17
573 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 351
