소개
Use this guide to remove or replace the front assembly on the General Wire Drain Cleaner RSVD 2014.
필요한 것
Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
