주요 콘텐츠로 건너뛰기
Generic TV Remote IR LED Replacement
필요한 것
  1. Generic TV Remote IR LED Replacement, IR LED: 1 단계, 이미지 1/2 Generic TV Remote IR LED Replacement, IR LED: 1 단계, 이미지 2/2
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
  2. Generic TV Remote IR LED Replacement: 2 단계, 이미지 1/3 Generic TV Remote IR LED Replacement: 2 단계, 이미지 2/3 Generic TV Remote IR LED Replacement: 2 단계, 이미지 3/3
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
  3. Generic TV Remote IR LED Replacement: 3 단계, 이미지 1/1
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
  4. Generic TV Remote IR LED Replacement: 4 단계, 이미지 1/1
    • Desolder the broken LED using a soldering iron and desoldering braid.
  5. Generic TV Remote IR LED Replacement: 5 단계, 이미지 1/1
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
  6. Generic TV Remote IR LED Replacement: 6 단계, 이미지 1/3 Generic TV Remote IR LED Replacement: 6 단계, 이미지 2/3 Generic TV Remote IR LED Replacement: 6 단계, 이미지 3/3
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
  7. Generic TV Remote IR LED Replacement: 7 단계, 이미지 1/1
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Geoffrey Smith
회원 가입일: 06/01/16
151 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 113
전체 시간: 12,791
