주요 콘텐츠로 건너뛰기
Geolia Hose spray gun Handle Replacement
필요한 것
  1. Geolia Hose spray gun Handle Replacement, Problem description: 1 단계, 이미지 1/1
    • The lever opening the water inlet is obviously too thin and a breaks after even a moderately long use.
  2. Geolia Hose spray gun Handle Replacement, Disassemble the lever: 2 단계, 이미지 1/1
    • This is rather easy, unscrew the plastic grey screw and drill the aluminium rivet to undo the lever
  3. Geolia Hose spray gun Handle Replacement, Creating the steel replacement lever: 3 단계, 이미지 1/2 Geolia Hose spray gun Handle Replacement, Creating the steel replacement lever: 3 단계, 이미지 2/2
    • This is a rather difficult part, I found a crop strip of steel of good thickness and width. Here about 3mm thick.
    • The worst part of it is to create a "oblong" hole in it to replace the initial plastic moulded part.
    • I did this with my small milling machine. If you do not have this machine, you might find some alternative, but this is definitely the most demanding part.
  4. Geolia Hose spray gun Handle Replacement, Bending the steel strip: 4 단계, 이미지 1/1
    • Again, not very easy, I bend the strip approximately to match the inital lever.
  5. Geolia Hose spray gun Handle Replacement, Completing the lever with oak support: 5 단계, 이미지 1/2 Geolia Hose spray gun Handle Replacement, Completing the lever with oak support: 5 단계, 이미지 2/2
    • The revolute joint is of the knuckle type, here I used a piece of oak wood to it. It is quite tricky to model the wood to the curvature of the bended metal strip. Both are quite strong. I used combination of jigsaw, milling machine, grinder etc to obtain the final result.
    • A paint on the steel part will be necessary to provide rust resistance.
결론
Michal Ruzek
회원 가입일: 01/27/22
655 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 75
