주요 콘텐츠로 건너뛰기
George Foreman GR-20 Disassembly
필요한 것
  1. George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: 1 단계, 이미지 1/2 George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: 1 단계, 이미지 2/2
    • Open the grill and remove the two Phillips #2 screws from the top lid.
  2. George Foreman GR-20 Disassembly: 2 단계, 이미지 1/3 George Foreman GR-20 Disassembly: 2 단계, 이미지 2/3 George Foreman GR-20 Disassembly: 2 단계, 이미지 3/3
    • Using a pick, peel off the model number sticker to expose the two screws underneath. Remove these screws using a Phillips #2 screwdriver.
  3. George Foreman GR-20 Disassembly: 3 단계, 이미지 1/2 George Foreman GR-20 Disassembly: 3 단계, 이미지 2/2
    • Remove the Phillips #2 screw from the orange tab.
    • Detach the top lid from the bottom of the grill.
  4. George Foreman GR-20 Disassembly: 4 단계, 이미지 1/2 George Foreman GR-20 Disassembly: 4 단계, 이미지 2/2
    • To measure the resistance of the heating coil, disconnect the blue wire from the heating element.
  5. George Foreman GR-20 Disassembly: 5 단계, 이미지 1/1
    • To access the underside of the grill, flip the grill over and remove the rubber bottoms of the two front feet to expose the screws.
  6. George Foreman GR-20 Disassembly: 6 단계, 이미지 1/1
    • Remove the two screws using a Phillips #2 screwdriver.
  7. George Foreman GR-20 Disassembly: 7 단계, 이미지 1/2 George Foreman GR-20 Disassembly: 7 단계, 이미지 2/2
    • Remove the two Phillips #2 screws in front of the two back feet.
  8. George Foreman GR-20 Disassembly: 8 단계, 이미지 1/2 George Foreman GR-20 Disassembly: 8 단계, 이미지 2/2
    • To remove the power cord from the device, remove the two Phillips #2 screws keeping the power cord and the blue and white wires connected.
  9. George Foreman GR-20 Disassembly: 9 단계, 이미지 1/1
    • After removing the screws, slide the blue and white wires out through the gap.
    • You will now have access to the underside of the grill.
  10. George Foreman GR-20 Disassembly: 10 단계, 이미지 1/2 George Foreman GR-20 Disassembly: 10 단계, 이미지 2/2
    • Remove the two Phillips #2 screws attaching the fuse to the grill.
    • Remove the fuse from the grill.
  11. George Foreman GR-20 Disassembly: 11 단계, 이미지 1/1
    • Remove the Phillips #2 screw from the white wire.
    • Remove the white wire from the grill.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aidan Admadjaja
회원 가입일: 09/16/20
264 평판
안내서 1개 작성함
댓글 한 개
Thanks to this, I've been able to fix my George Foreman grill! Absolute blessing!
OK GGS - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 32
전체 시간: 995
