주요 콘텐츠로 건너뛰기
George Foreman Wire Repair
필요한 것
  1. George Foreman Wire Repair, George Foreman Wire Repair: 1 단계, 이미지 1/1
    • Make sure the appliance is unplugged and cooled off before beginning the repair.
    • If the appliance is still on, this could lead to safety hazards such as burning of the hand or electrocution.
    • Lights will appear lit if the appliance is still on so make sure the lights are not illuminated.
  2. George Foreman Wire Repair: 2 단계, 이미지 1/1
    • Open the appliance by lifting the top plate away from you.
  3. George Foreman Wire Repair: 3 단계, 이미지 1/2 George Foreman Wire Repair: 3 단계, 이미지 2/2
    • Remove the plates by pushing down on the black knobs on either side of the plates, top and bottom.
    • After, pick up and lift the plates off of the appliance.
  4. George Foreman Wire Repair: 4 단계, 이미지 1/3 George Foreman Wire Repair: 4 단계, 이미지 2/3 George Foreman Wire Repair: 4 단계, 이미지 3/3
    • Underneath where the plates sit you will see a coil and 12 screws holding the base plate in place.
    • Remove the 12 Phillips head screws on the bottom plate with a #1 Phillips head screw driver.
  5. George Foreman Wire Repair: 5 단계, 이미지 1/1
    • After unscrewing the screws, lift off the base plate.
    • This is where you will see the wires.
  6. George Foreman Wire Repair: 6 단계, 이미지 1/2 George Foreman Wire Repair: 6 단계, 이미지 2/2
    • Re-establish the disconnected or loose wires by pushing them back into the point of connection.
    • Push the wires into the connection center on the bottom of the plate until you can't anymore. This is how you know they will not come loose again.
    • Make sure to keep the wires separated so they do not touch and become tangled to avoid sparks and electrocution.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ali Sealby
회원 가입일: 07/02/18
163 평판
안내서 1개 작성함
댓글 한 개
Unable to repair the split cord on my George Foreman small health fit grill model 25800 as the plates are screwed on. Please advise.
Ann Holdsworth - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 22
30일 전: 59
전체 시간: 2,026
