도구
부품
지정된 부품이 없습니다.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the plates by pushing down on the black knobs on either side of the plates, top and bottom.
After, pick up and lift the plates off of the appliance.
Remove the 12 Phillips head screws on the bottom plate with a #1 Phillips head screw driver.
After unscrewing the screws, lift off the base plate.
This is where you will see the wires.
Re-establish the disconnected or loose wires by pushing them back into the point of connection.
Push the wires into the connection center on the bottom of the plate until you can't anymore. This is how you know they will not come loose again.
다른 한 분이 해당 안내서를 완성하였습니다.
