주요 콘텐츠로 건너뛰기
Getting randomly stuck at 100% input
필요한 것
  1. Getting randomly stuck at 100% input, Perform Maintenance: 1 단계, 이미지 1개 중 1개
    • You can find a guide on how to perform that here.
  2. Getting randomly stuck at 100% input, Remove your carpet: 2 단계, 이미지 1개 중 1개
    • If you have a carpet underneath your setup, remove it.
    • If the carpet is built into the floor, buy an anti-static floor mat to fit underneath your setup.
    • Create a path from your rig or pedals to Earth, so that static electricity would dissipate through it.
    • Not all homes have grounding built-in. You may need to get creative or create grounding yourself.
    • Understanding the ESD is important. Read more about it here, here and here.
결론
Eliminating possibility of Electro-Static Discharge will prevent your pedal getting randomly stuck at 100% or 50% input.
작성자
2다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,595 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 193
