주요 콘텐츠로 건너뛰기
Ghost Longboard Wheel Replacement
필요한 것
  1. Ghost Longboard Wheel Replacement, Wheel: 1 단계, 이미지 1/1
    • Using a 15 mm socket wrench, unscrew the axle nut.
  2. Ghost Longboard Wheel Replacement: 2 단계, 이미지 1/1
    • Using your fingers, remove the axle nut from the axle.
  3. Ghost Longboard Wheel Replacement: 3 단계, 이미지 1/1
    • Remove the washer from the axle.
  4. Ghost Longboard Wheel Replacement: 4 단계, 이미지 1/1
    • Remove the wheel from the axle.
  5. Ghost Longboard Wheel Replacement: 5 단계, 이미지 1/1
    • Remove the second washer from the axle.
  6. Ghost Longboard Wheel Replacement: 6 단계, 이미지 1/1
    • Slide a new washer onto the axle.
  7. Ghost Longboard Wheel Replacement: 7 단계, 이미지 1/2 Ghost Longboard Wheel Replacement: 7 단계, 이미지 2/2
    • Place the new wheel on the axle.
    • Be sure to position the flat side of the wheel so it is facing inward.
  8. Ghost Longboard Wheel Replacement: 8 단계, 이미지 1/1
    • Place a second washer on the axle exterior to the wheel.
  9. Ghost Longboard Wheel Replacement: 9 단계, 이미지 1/1
    • Place an axle nut on the axle.
  10. Ghost Longboard Wheel Replacement: 10 단계, 이미지 1/1
    • Using a 15 mm socket wrench, tighten the axle nut.
    • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
결론
Repeat these steps on the three remaining wheels.
Patricia Roux
회원 가입일: 03/18/21
184 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 357
