주요 콘텐츠로 건너뛰기
Giant Reign 2 Headset Replacement
필요한 것
  1. Giant Reign 2 Headset Replacement, Hex Screws: 1 단계, 이미지 1개 중 1개
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Headset Replacement, Axle Screw: 2 단계, 이미지 2개 중 1개 Giant Reign 2 Headset Replacement, Axle Screw: 2 단계, 이미지 2개 중 2개
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Headset Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Headset Replacement, Front Wheel: 4 단계, 이미지 1개 중 1개
    • Pull the wheel from the fork.
  5. Giant Reign 2 Headset Replacement, Headset: 5 단계, 이미지 2개 중 1개 Giant Reign 2 Headset Replacement, Headset: 5 단계, 이미지 2개 중 2개
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
  6. Giant Reign 2 Headset Replacement: 6 단계, 이미지 3개 중 1개 Giant Reign 2 Headset Replacement: 6 단계, 이미지 3개 중 2개 Giant Reign 2 Headset Replacement: 6 단계, 이미지 3개 중 3개
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
  7. Giant Reign 2 Headset Replacement: 7 단계, 이미지 3개 중 1개 Giant Reign 2 Headset Replacement: 7 단계, 이미지 3개 중 2개 Giant Reign 2 Headset Replacement: 7 단계, 이미지 3개 중 3개
    • Slide off the spacers.
    • Lift off the seal.
  8. Giant Reign 2 Headset Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the fork out of the casing.
  9. Giant Reign 2 Headset Replacement: 9 단계, 이미지 1개 중 1개
    • Using your fingers, pry the bearings from the top and bottom of the headset.
  10. Giant Reign 2 Headset Replacement: 10 단계, 이미지 1개 중 1개
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
  11. Giant Reign 2 Headset Replacement: 11 단계, 이미지 2개 중 1개 Giant Reign 2 Headset Replacement: 11 단계, 이미지 2개 중 2개
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Sterling Grande
회원 가입일: 10/08/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G14
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 19
전체 시간: 4,147
