주요 콘텐츠로 건너뛰기
Giant Reign 2 Tube Replacement
필요한 것
  1. Giant Reign 2 Tube Replacement, Hex Screws: 1 단계, 이미지 1개 중 1개
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Tube Replacement, Axle Screw: 2 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement, Axle Screw: 2 단계, 이미지 2개 중 2개
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Tube Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Tube Replacement, Front Wheel: 4 단계, 이미지 1개 중 1개
    • Pull the wheel from the fork.
  5. Giant Reign 2 Tube Replacement, Tube: 5 단계, 이미지 1개 중 1개
    • Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
    • Bike tubes come with one of two standard valve types: presta and schrader. These guides show the installation of a tube with a presta valve.
  6. Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 1개 Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 2개 Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 3개
    • Unscrew the cap covering the valve.
    • Remove the spacer that holds the valve in place against the rim of the wheel.
    • Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
  7. Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 1개 Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 2개 Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever adjacent to the first.
    • Slowly work one tire lever around the rim until the whole tire is loose.
  8. Giant Reign 2 Tube Replacement: 8 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 8 단계, 이미지 2개 중 2개
    • Press the valve through the rim of the wheel.
    • Remove the tube from the tire.
  9. Giant Reign 2 Tube Replacement: 9 단계, 이미지 1개 중 1개
    • Partially inflate the tube.
  10. Giant Reign 2 Tube Replacement: 10 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 10 단계, 이미지 2개 중 2개
    • Push the valve through the rim.
    • Push the tube into the tire all the way around the rim of the wheel.
  11. Giant Reign 2 Tube Replacement: 11 단계, 이미지 1개 중 1개
    • Push the bead of the tire back into place around the rim.
    • Make sure not to pinch the tube between the bead of the tire and the rim. Failure to do so may cause a pinch flat.
  12. Giant Reign 2 Tube Replacement: 12 단계, 이미지 1개 중 1개
    • Inflate the tube to the desired air pressure.
    • A suggested range of air pressure is located on the wall of the tire (formatted ##-##psi).
  13. Giant Reign 2 Tube Replacement: 13 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 13 단계, 이미지 2개 중 2개
    • Close the valve and replace the cap.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sterling Grande
회원 가입일: 10/08/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G14
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 14
전체 시간: 2,968
