주요 콘텐츠로 건너뛰기
Giant Talon 29er Chainring Replacement
필요한 것
  1. Giant Talon 29er Chainring Replacement, Chainring: 1 단계, 이미지 1/3 Giant Talon 29er Chainring Replacement, Chainring: 1 단계, 이미지 2/3 Giant Talon 29er Chainring Replacement, Chainring: 1 단계, 이미지 3/3
    • Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
    • Unroute the chain from the chainrings.
  2. Giant Talon 29er Chainring Replacement: 2 단계, 이미지 1/1
    • Remove the 8 mm Hex screw from the crank arm.
  3. Giant Talon 29er Chainring Replacement: 3 단계, 이미지 1/1
    • Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
  4. Giant Talon 29er Chainring Replacement: 4 단계, 이미지 1/1
    • Remove the four 5 mm Hex screws that mount the crank arm to the chainrings.
  5. Giant Talon 29er Chainring Replacement: 5 단계, 이미지 1/3 Giant Talon 29er Chainring Replacement: 5 단계, 이미지 2/3 Giant Talon 29er Chainring Replacement: 5 단계, 이미지 3/3
    • Rotate the largest chainring 45 degrees in either direction.
    • Remove the crank arm from the chainrings.
결론
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Ben Frisbie
회원 가입일: 03/22/16
209 평판
안내서 1개 작성함
Michigan Tech, Team 1-7, Lauer Spring 2016 Michigan Tech, Team 1-7, Lauer Spring 2016 회원
MTU-LAUER-S16S1G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 25
전체 시간: 3,437
