주요 콘텐츠로 건너뛰기
Gigabyte P34G Hard Drive Replacement
필요한 것
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Hard Drive Replacement: 2 단계, 이미지 1/2 Gigabyte P34G Hard Drive Replacement: 2 단계, 이미지 2/2
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
  3. Gigabyte P34G Hard Drive Replacement: 3 단계, 이미지 1/1
    • Carefully lift the hard drive for removal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
yeunghayden
회원 가입일: 05/01/15
841 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 회원
CPSU-REGAN-S15S8G1
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 3,377
