주요 콘텐츠로 건너뛰기
Gigabyte P34G Wireless Card Replacement
필요한 것
  1. Gigabyte P34G Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Wireless Card Replacement: 2 단계, 이미지 1/1
    • Remove the screw attaching the wireless card to the motherboard.
    • Save the screw in a safe place for reassembly later.
  3. Gigabyte P34G Wireless Card Replacement: 3 단계, 이미지 1/1
    • Remove the black and grey wires that are connected to the wireless card by pulling away from the card.
  4. Gigabyte P34G Wireless Card Replacement: 4 단계, 이미지 1/1
    • Carefully pull the wireless card out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
yeunghayden
회원 가입일: 05/01/15
841 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 회원
CPSU-REGAN-S15S8G1
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 1,400
