주요 콘텐츠로 건너뛰기
Glass Door Latch Replacement
필요한 것
  1. Glass Door Latch Replacement, Outer Removal: 1 단계, 이미지 1/3 Glass Door Latch Replacement, Outer Removal: 1 단계, 이미지 2/3 Glass Door Latch Replacement, Outer Removal: 1 단계, 이미지 3/3
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: 2 단계, 이미지 1/3 Glass Door Latch Replacement, Preparation: 2 단계, 이미지 2/3 Glass Door Latch Replacement, Preparation: 2 단계, 이미지 3/3
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: 3 단계, 이미지 1/2 Glass Door Latch Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: 4 단계, 이미지 1/2 Glass Door Latch Replacement, Mechanism Removal: 4 단계, 이미지 2/2
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: 5 단계, 이미지 1/2 Glass Door Latch Replacement, Replacement Prep: 5 단계, 이미지 2/2
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: 6 단계, 이미지 1/3 Glass Door Latch Replacement, Installation: 6 단계, 이미지 2/3 Glass Door Latch Replacement, Installation: 6 단계, 이미지 3/3
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: 7 단계, 이미지 1/3 Glass Door Latch Replacement, Installation Cont.: 7 단계, 이미지 2/3 Glass Door Latch Replacement, Installation Cont.: 7 단계, 이미지 3/3
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: 8 단계, 이미지 1/2 Glass Door Latch Replacement, Latch Correction: 8 단계, 이미지 2/2
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: 9 단계, 이미지 1/3 Glass Door Latch Replacement, Handle Placement: 9 단계, 이미지 2/3 Glass Door Latch Replacement, Handle Placement: 9 단계, 이미지 3/3
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
결론
CJ Cummings
회원 가입일: 05/04/20
169 평판
안내서 1개 작성함
UW Tacoma, Team S1-G32, Cardinal Spring 2020 UW Tacoma, Team S1-G32, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G32
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 46
30일 전: 167
전체 시간: 6,704
