주요 콘텐츠로 건너뛰기
GoPro HD Hero2 Rear Case Replacement
필요한 것
  1. GoPro HD Hero2 Rear Case Replacement, Back Cover: 1 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement, Back Cover: 1 단계, 이미지 2/2
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 Rear Case Replacement, Battery: 2 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement, Battery: 2 단계, 이미지 2/2
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 Rear Case Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the case.
  4. GoPro HD Hero2 Rear Case Replacement, Rear Case: 4 단계, 이미지 1/1
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 Rear Case Replacement: 5 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement: 5 단계, 이미지 2/2
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 Rear Case Replacement: 6 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement: 6 단계, 이미지 2/2
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 Rear Case Replacement: 7 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement: 7 단계, 이미지 2/2
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  8. GoPro HD Hero2 Rear Case Replacement: 8 단계, 이미지 1/3 GoPro HD Hero2 Rear Case Replacement: 8 단계, 이미지 2/3 GoPro HD Hero2 Rear Case Replacement: 8 단계, 이미지 3/3
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  9. GoPro HD Hero2 Rear Case Replacement, SD Board: 9 단계, 이미지 1/1
    • Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
  10. GoPro HD Hero2 Rear Case Replacement: 10 단계, 이미지 1/3 GoPro HD Hero2 Rear Case Replacement: 10 단계, 이미지 2/3 GoPro HD Hero2 Rear Case Replacement: 10 단계, 이미지 3/3
    • Turn the rear case over so that the SD card slot is facing you.
    • Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case.
    • Turn the rear case back over.
    • Lift the SD board cover out of the rear case with the tip of a spudger and remove it.
  11. GoPro HD Hero2 Rear Case Replacement: 11 단계, 이미지 1/2 GoPro HD Hero2 Rear Case Replacement: 11 단계, 이미지 2/2
    • Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
  12. GoPro HD Hero2 Rear Case Replacement, Rear Case: 12 단계, 이미지 1/1
    • The rear case remains.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,493 평판
안내서 127개 작성하였습니다
댓글 한 개
FYI the item that you're disassembling is not the SD card slot, it's the plug for HD Hero accessories such as the Wifi backpack and LCD screen. The SD card is inserted from the side not the back.
Mike Keane - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 2,873
