소개
Use this guide to replace the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
필요한 것
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Pry around the panel to ensure it is not attached to the device.
Move the panel to the side so you can access the internal components.
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
Use a pair of tweezers to disconnect the battery connector from the motherboard.
Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
Lift the battery connector straight up.
hi what kind battery can replace for hero+?
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Very helpful guide
No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
WPN - 답글
