주요 콘텐츠로 건너뛰기
GoPro Hero 3 Silver Image Sensor Replacement
필요한 것
  1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: 1 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement, Battery: 1 단계, 이미지 2/2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Image Sensor Replacement: 2 단계, 이미지 1/1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 3 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 3 단계, 이미지 2/2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Image Sensor Replacement: 4 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement: 4 단계, 이미지 2/2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Image Sensor Replacement: 5 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement: 5 단계, 이미지 2/2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Image Sensor Replacement: 6 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement: 6 단계, 이미지 2/2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Image Sensor Replacement: 7 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement: 7 단계, 이미지 2/2
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. GoPro Hero 3 Silver Image Sensor Replacement: 8 단계, 이미지 1/2 GoPro Hero 3 Silver Image Sensor Replacement: 8 단계, 이미지 2/2
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jose Villa
회원 가입일: 04/01/15
297 평판
안내서 1개 작성함
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 21개 작성하였습니다
댓글 2개
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - 답글
Your pictures are really dark.
Nick Ruiz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 1,898
