필요한 것
Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
You should now be able to remove the image sensor by simply pulling it.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
