주요 콘텐츠로 건너뛰기
  1. Pull back on the tab on the back of GoPro to open the battery cover. Pull back on the tab on the back of GoPro to open the battery cover.
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. Pull the battery out using the tab.
    • Pull the battery out using the tab.
  3. Use the plastic opening tool to remove the faceplate. There is some adhesive and clips so be careful and the faceplate should pop right off.
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. Now that the faceplate is off, it is time to remove the 4 screws on each corner. Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier. Using the plastic opening tool, slowly pry open the motherboard assembly.
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. Use the spudger to gently pry off the connector of the housing to the motherboard. You should now have the motherboard assembly and the housing separated.
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard. Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
  8. Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off. You should now be able to remove the image sensor by simply pulling it.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • You should now be able to remove the image sensor by simply pulling it.
    Where i can buy the image sensor, and for how much
    Yudha prabowo - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jose Villa
회원 가입일: 2015년 04월 01일
291 평판
안내서 1개 작성함
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 21개 작성하였습니다
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - 답글
Your pictures are really dark.
Nick Ruiz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 1,578
