소개
Use this guide to replace the LCD housing on your GoPro Hero3 Silver.
필요한 것
Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Use the spudger to gently pry off the connector of the housing to the motherboard.
You should now have the motherboard assembly and the housing separated.
At this point you can easily change the LCD assembly by unplugging the ribbon and removing the existing screen. No need to proceed further if you're only replacing the screen.
다른 5명이 해당 안내서를 완성하였습니다.
