주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Use this guide to replace the LCD housing on your GoPro Hero3 Silver.
  1. Pull back on the tab on the back of GoPro to open the battery cover. Pull back on the tab on the back of GoPro to open the battery cover.
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. Pull the battery out using the tab.
    • Pull the battery out using the tab.
  3. Use the plastic opening tool to remove the faceplate. There is some adhesive and clips so be careful and the faceplate should pop right off.
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. Now that the faceplate is off, it is time to remove the 4 screws on each corner. Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier. Using the plastic opening tool, slowly pry open the motherboard assembly.
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. Use the spudger to gently pry off the connector of the housing to the motherboard. You should now have the motherboard assembly and the housing separated.
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
    At this point you can easily change the LCD assembly by unplugging the ribbon and removing the existing screen. No need to proceed further if you're only replacing the screen.
    Nick Goulet - 답글
  7. Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard. Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens. Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  8. The media adapter is attached to the motherboard via 3 screws: x1 T4 Torx x2 Phillips #00
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
  9. Use the spudger to lift the black tab up to unlock. Then remove LCD screen connector by sliding  out. Then remove LCD screen connector by sliding  out.
    • Use the spudger to lift the black tab up to unlock.
    • Then remove LCD screen connector by sliding out.
  10. Using the Phillips head bit, remove the silver screw near the the top edge of the board. Separate the LCD assembly by pulling away the motherboard. Separate the LCD assembly by pulling away the motherboard.
    • Using the Phillips head bit, remove the silver screw near the the top edge of the board.
    • Separate the LCD assembly by pulling away the motherboard.
  11. There are 3 Phillips #00 screws holding the lens onto the LCD housing that need to be removed. Our screw on the top right is stripped, which is why it looks different. However, they will all look the same in your device.
    • There are 3 Phillips #00 screws holding the lens onto the LCD housing that need to be removed.
    • Our screw on the top right is stripped, which is why it looks different. However, they will all look the same in your device.
  12. Carefully remove the camera lens from the LCD Housing. Now you have the LCD housing removed!
    • Carefully remove the camera lens from the LCD Housing.
    • Now you have the LCD housing removed!
결론
다른 4명이 해당 안내서를 완성하였습니다.
Brian Alvarez
회원 가입일: 2015년 04월 02일
1,346 평판
안내서 6개 작성하였습니다
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 14개 작성하였습니다
Excellent walkthrough. Thank you Brian!
Nick Goulet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 7,775
