주요 콘텐츠로 건너뛰기
GoPro Hero 3 Silver Motherboard Replacement
필요한 것
  1. GoPro Hero 3 Silver Motherboard Replacement, Battery: 1 단계, 이미지 1/2 GoPro Hero 3 Silver Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Motherboard Replacement: 2 단계, 이미지 1/1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Motherboard Replacement: 4 단계, 이미지 1/2 GoPro Hero 3 Silver Motherboard Replacement: 4 단계, 이미지 2/2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Motherboard Replacement: 5 단계, 이미지 1/2 GoPro Hero 3 Silver Motherboard Replacement: 5 단계, 이미지 2/2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Motherboard Replacement: 6 단계, 이미지 1/2 GoPro Hero 3 Silver Motherboard Replacement: 6 단계, 이미지 2/2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 1/3 GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 2/3 GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 3/3
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  8. GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 1/3 GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 2/3 GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 3/3
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
  9. GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 1/3 GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 2/3 GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 3/3
    • Use the spudger to lift the black tab up to unlock.
    • Then remove LCD screen connector by sliding out.
  10. GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 1/3 GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 2/3 GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 3/3
    • Using the Phillips head bit, remove the silver screw near the top edge of the board.
    • Separate the LCD assembly by pulling it away. You should have the bare motherboard!
결론
다른 16명이 해당 안내서를 완성하였습니다.
Brian Alvarez
회원 가입일: 04/02/15
1,439 평판
안내서 6개 작성하였습니다
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 8,284
