소개
If you are having trouble with your USB connection you might need to replace the USB port. This is a guide for replacing the USB connection port on the Hero4 Black.
필요한 것
First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
After loosening the clips on the edge, pull the faceplate off.
거의 끝나갑니다!
결론
다른 8명이 해당 안내서를 완성하였습니다.
