주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In order to replace or fix components in this camera, it is necessary to take of the back and get to the "guts" of the camera. This is because the camera does not come out of the case.
  1. Power off your GoPro before beginning disassembly.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. Gently pry the back open by inserting a metal spudger between the case and back panel.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. Carefully remove the motherboard and white plastic piece from the case.
    • Carefully remove the motherboard and white plastic piece from the case.
결론
River Drake
회원 가입일: 2015년 04월 02일
981 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 104
