소개
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
필요한 것
Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 3개
Where do you buy the replacement lcd
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
I can find the screen but is it compatible with the Hero+
