주요 콘텐츠로 건너뛰기
GoPro Hero LCD Screen Replacement
필요한 것
  1. GoPro Hero LCD Screen Replacement, Casing: 1 단계, 이미지 1/1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: 2 단계, 이미지 1/1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: 4 단계, 이미지 1/1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: 6 단계, 이미지 1/1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: 7 단계, 이미지 1/2 GoPro Hero LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2/2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - 답글
  8. GoPro Hero LCD Screen Replacement: 8 단계, 이미지 1/1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: 9 단계, 이미지 1/1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: 10 단계, 이미지 1/2 GoPro Hero LCD Screen Replacement: 10 단계, 이미지 2/2
    • Separate the LCD screen from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
River Drake
회원 가입일: 04/02/15
1,035 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개 작성하였습니다
댓글 3개
Where do you buy the replacement lcd
Anthony Volatile - 답글
I can find the screen but is it compatible with the Hero+
Brian Casado - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 73
30일 전: 320
전체 시간: 22,579
