주요 콘텐츠로 건너뛰기
GoPro Hero Lens Replacement
필요한 것
  1. GoPro Hero Lens Replacement, Casing: 1 단계, 이미지 1/1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Lens Replacement: 2 단계, 이미지 1/1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Lens Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Lens Replacement: 4 단계, 이미지 1/1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Lens Replacement: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Lens Replacement: 6 단계, 이미지 1/1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Lens Replacement, Lens: 7 단계, 이미지 1/1
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
  8. GoPro Hero Lens Replacement: 8 단계, 이미지 1/1
    • Remove the lens from the case.
    Spot on... Contacted Gopro preciously & they say it's not a replaceable item!.. how wrong are they!
    Thank you.
    Gary Traviss - 답글
결론
To reassemble your device, follow the instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
River Drake
회원 가입일: 04/02/15
1,023 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 32
30일 전: 66
전체 시간: 12,404
