소개
This guide will entail taking all of the GoPro's components out, as the lens is at the bottom. Because the GoPro Hero is not very repairable, this guide is not for the faint of heart. However, if you follow the steps correctly, you should be able to replace the lens, instead of buying a new camera.
필요한 것
Remove the lens from the case.
Spot on... Contacted Gopro preciously & they say it's not a replaceable item!.. how wrong are they!
Thank you.
To reassemble your device, follow the instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
