이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Gently pry the back open by inserting a metal spudger between the case and back panel.
Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
Carefully remove the motherboard and white plastic piece from the case.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
