주요 콘텐츠로 건너뛰기
GoPro Hero Motherboard Replacement
필요한 것
  1. GoPro Hero Motherboard Replacement, Casing: 1 단계, 이미지 1/1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: 2 단계, 이미지 1/1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: 6 단계, 이미지 1/1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 GoPro Hero Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: 8 단계, 이미지 1/2 GoPro Hero Motherboard Replacement: 8 단계, 이미지 2/2
    • Separate the white plastic piece from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Zoe Tuggle
회원 가입일: 04/01/15
179 평판
안내서 1개 작성함
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개 작성하였습니다
댓글 2개
So after doing all theses steps did it resolve the problem
Anita - 답글
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 42
전체 시간: 10,100
