주요 콘텐츠로 건너뛰기
GoPro Hero3+ Silver Edition Camera Lens Replacement
필요한 것
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: 3 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 2개 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 5 단계, 이미지 3개 중 3개
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: 8 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement: 8 단계, 이미지 2개 중 2개
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: 9 단계, 이미지 1개 중 1개
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: 10 단계, 이미지 2개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement: 10 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: 12 단계, 이미지 3개 중 1개 GoPro Hero3+ Silver Edition Camera Lens Replacement: 12 단계, 이미지 3개 중 2개 GoPro Hero3+ Silver Edition Camera Lens Replacement: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: 13 단계, 이미지 1개 중 1개
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: 14 단계, 이미지 1개 중 1개
    • Carefully remove the lens from the font housing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Patrick Cook
회원 가입일: 10/01/15
699 평판
안내서 3개를 작성함
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 회원
CPSU-MANESS-F15S5G8
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 9
전체 시간: 2,308
