주요 콘텐츠로 건너뛰기
GoPro Hero4 Black Camera Sensor Replacement
필요한 것
  1. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 1 단계, 이미지 1/3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 1 단계, 이미지 2/3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 1 단계, 이미지 3/3
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Camera Sensor Replacement: 2 단계, 이미지 1/2 GoPro Hero4 Black Camera Sensor Replacement: 2 단계, 이미지 2/2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Camera Sensor Replacement: 3 단계, 이미지 1/2 GoPro Hero4 Black Camera Sensor Replacement: 3 단계, 이미지 2/2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Camera Sensor Replacement: 4 단계, 이미지 1/3 GoPro Hero4 Black Camera Sensor Replacement: 4 단계, 이미지 2/3 GoPro Hero4 Black Camera Sensor Replacement: 4 단계, 이미지 3/3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 5 단계, 이미지 1/3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 5 단계, 이미지 2/3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 5 단계, 이미지 3/3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Camera Sensor Replacement: 6 단계, 이미지 1/3 GoPro Hero4 Black Camera Sensor Replacement: 6 단계, 이미지 2/3 GoPro Hero4 Black Camera Sensor Replacement: 6 단계, 이미지 3/3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jeffrey Goethe
회원 가입일: 02/20/17
665 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 2개
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
popoypoi22 - 답글
Hi, is the sensor for black and silver same? Thank you
Jakub Kunický - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 39
전체 시간: 3,845
