주요 콘텐츠로 건너뛰기
GoPro Hero4 Black Expansion Port/Motherboard Replacement
필요한 것
  1. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: 1 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: 1 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Midframe Housing: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 2 단계, 이미지 2개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 3 단계, 이미지 2개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 4 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 4 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: 5 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: 5 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Camera Sensor: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 6 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 6 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: 7 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: 7 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement, Expansion Port: 7 단계, 이미지 3개 중 3개
    • Using #00 phillips head screwdriver, remove the 3.0mm screw.
    • Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
  8. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 8 단계, 이미지 2개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, lift the motherboard from the midframe housing
    • It may feel like the board is still attached with a screw or two. Gentle, but firm wiggling will free the board.
  9. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 9 단계, 이미지 3개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 9 단계, 이미지 3개 중 2개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using #00 phillips head screwdriver, remove the three 4.0mm screws.
    • Using plastic opening tool, unclip Expansion Port chip from motherboard
    • A metal piece of the frame sits underneath the bottom screw, which will detach upon removing the screw.
  10. GoPro Hero4 Black Expansion Port/Motherboard Replacement: 10 단계, 이미지 2개 중 1개 GoPro Hero4 Black Expansion Port/Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the expansion port chip from the motherboard.
    • It is now possible to replace the expansion port and/or motherboard.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jeffrey Goethe
회원 가입일: 02/20/17
674 평판
안내서 3개를 작성함
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
step 2 is wrong, short screw belongs on the battery door edge... destroyed my new housing... :(
Menno Middelkoop - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 68
전체 시간: 6,553
