소개
Use this guide to replace a malfunctioning motherboard or expansion port. Because replacing either part requires the same steps, they are both combined into one guide.
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using #00 phillips head screwdriver, remove the 3.0mm screw.
Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
다른 9명이 해당 안내서를 완성하였습니다.
