소개
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
필요한 것
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
다른 5명이 해당 안내서를 완성하였습니다.
