주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
GoPro Hero4 Black Midframe Housing Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: 1 단계, 이미지 1/3 GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: 1 단계, 이미지 2/3 GoPro Hero4 Black Midframe Housing Replacement, Midframe Housing: 1 단계, 이미지 3/3
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Midframe Housing Replacement: 2 단계, 이미지 1/2 GoPro Hero4 Black Midframe Housing Replacement: 2 단계, 이미지 2/2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Midframe Housing Replacement: 3 단계, 이미지 1/2 GoPro Hero4 Black Midframe Housing Replacement: 3 단계, 이미지 2/2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Midframe Housing Replacement: 4 단계, 이미지 1/3 GoPro Hero4 Black Midframe Housing Replacement: 4 단계, 이미지 2/3 GoPro Hero4 Black Midframe Housing Replacement: 4 단계, 이미지 3/3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
결론
Thomas Sullivan
회원 가입일: 02/20/17
589 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
