소개
In this guide we will be showing you how to replace the speaker assembly in your GoPro Hero4 Silver. The speaker allows for audio playback when viewing recorded videos. Before you begin make sure the battery is removed from the device and that you have the necessary tools to preform this repair.
필요한 것
Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
The seven plastic tab locations are marked in red.
Remove the three 8 mm Phillips #000 screws on each corner of the camera.
Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
The sensor has ribbon cables running to the motherboard via a black rectangular connector.
To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
With the old camera sensor assembly removed, you can now replace it with a new sensor.
Remove the three 8 mm Phillips #000 screws securing the Hero port to the motherboard.
Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector by flipping up the black retaining flap. You should then be able to pull the cable free.
Once the ribbon cable is disconnected, you can remove the black plastic bracket which holds the camera lens.
Flip the motherboard assembly and camera housing over so you can access the back of the motherboard.
Look for the white connector that has two wires that lead from the mother board to the battery compartment in the camera housing.
Using the metal tweezers, pull upward on the connector to disconnect the clip.
다른 한 분이 해당 안내서를 완성하였습니다.
